Is it possible to use the inputs on the RGBW module to sense changes on a non voltage set of relays i.e. dry contacts?
6 answers to this question
It should work but in 4.035 RGBW in/out mode is broken (it's under "known issues" in the firmware thread).
    Thanks Peter, that would seem to be the reason it doesn't work
    Peter is right, it does not work in 4.x. Gotta go back to 3.6 to get it work.
    Is there a schedule to fix this issue figaro?
    Thanks for your input guys
    Seems this issue still has not been addressed in the latest update
    Can anyone tell me how i can go back to 3.6? Really need to get this feature up and running asap.
