Modbus control from HC2
Mackan79
Hi
I have a project at home, where I want to read data from my floor heating controlsystem and heating system.
Those systems have Modbus RTU, and I have a gateway which convert it to Modbus TCP-IP.
Is there any way to read data from modbus in HC2? If so, how could I get the information from the modbus register? Can look like: Register 50006, Temperature, 16bit value.
The gateway can be set to "Transparent modbus/tcp to modbus/rtu", i.e to reach the information I first need to access 192.168.1.90 and then the modbus register.
Any help is appreciated!
Best Regards,
Marcus
6 answers to this question
Hi Marcus,
this is a small example on how to communicate via Modbus:
Hello
  Can you help me with the correct implementation of the codes.
I need the values of this register.
how can I best implement.
With Simpli modbus this program I can read but how do I do with the code.
00 01 00 00 00 06 01 03 00 43 00 02
Funktion 03H : READ HOLDING REGISTERS
Register       Beschreibung                                Länge  Datentyp
40068          Photovoltaik-Leistung in Watt        2          Int32
Or this code
But the debug is
answer is instructive
Please help me with a example.
I find this interesting. I think about buying a modbus adapter for my ventilation, but trying to consider cost vs usable functions and fun of the challenge.
Remember to include limit while comparing either [ < OR >= ] or [ <= OR ]
What if someNumber = 2147483647  ?
Better remove the first if, and hav return after the second if
I don't know what goes on in the scene but the number equal to: 231 − 1
If you use a signed 32 bit data type it would be the larges positive number you can have. The first bit is used for the sign 0: positive and 1: negative.
Bonjour je suis a la recherche de quelqu'un qui serais capable de faire une VD modbus/ TCP/IP pour le logo8 De Chez Siemens ? une idée ?
Merci a tous pour votre aide.
Voir traduction google merci
Edited by DGDIM
