Wall Plug
Guest David86vm
Should it be normal when manualy turning on or off the fibaro wall plug the hc2 does not change state?
already tried to remove and add the sync again.
I've tested it 2 seconds ago... It works with 4.036. Which version do you have?
Guest David86vm
    also 4.036
    And you can switch it on/off over the hc2?
    Guest David86vm
    Yes that works fine trough the iphone app also. But never gives feedback to the hc2 when used manualy
    Do you have a value on the interval setting? Mine is "0" and when I change it after save it's back on "0" could that cause the problem ?
    Polling time is not working. I have 0, too...
    I recently had the problem, that I could not switch off the plug. But the light is going on/off. :/
    I have pulled the plug from the socket and put it into another socket... Since then it works again. Maybe give it a try...
    Guest David86vm
    Disconnected te plug wait for 5 min then replugged, is still same issue
    Maybe a hardware-reset of your plug helps...
    Guest David86vm
    After a Hardware reset no difference...
    Than i removed the device from the hc2 by triple click the button after adding it as a new device is now works well.
