What Motorised Valve can you suggest to use with fibaro HC2
Hello! I have few water sensors and want to install a Motorized Valve to turn off water in case of emergency. What valve will work with fibaro HC2 and a Fibaro FGS-211 Relay Switch?
Please suggest. Thanks!
I'm using the Leak Gopher and so far it works great!
I'm on firmware version 4.036 on the HC2
Guest chaicka
Does Leak Gopher supports EU Z-Wave frequency?
