Dune HD Max - XML responds
Hi everyone,
moving on with the automation I am trying to automate my Dune HD Max video streamer. I have found the API document and I can send several commands.
The one that puzzles me most is reading the current player state:
The responds is similar to this:
How can I decode the info to just get the "player_state"? I know how this works in a JSON, but not in a XML layout.
Any help is appreciated
5 answers to this question
    Ok, making progress but to the correct result...
    This works, but the table is overwritten by itself meaning it only returns the last rule..
    That means during playback it makes this:
    into this
    It obviously needs to add a level extra so I can then filter the json table I get
    The goal offcourse is:
    or even better
    Ok, a long night puzzling I made progress:
    The player now returns multiple line:
    And I can pull values from this table:
    Now I would like to be able to create a loop doing:
    How to do this with a json table?
    I found this post very interesting because I am in the research stage of a home automation project and one of the key requirements *was* to interact with a Plex media server (via its web service) to obtain library  information. Although I have experience of scripting (in different languages) I am completely new to the HC2 environment. I am interested in this post for two reasons
    1) I want to know if the language the HC2 uses is capable of processing XML requests coming back from  a device (which I believe is what may be being asked here) without having to resort to parsing "<" and "/>" constructs
    2) I am also interested in the DUNE HD devices which have been mentioned.
    So I will be following this conversation with open eyes and I'm off to Google JSON which I had never heard of until two minutes ago!
    The language the HC2 uses is called LUA and is widely documented.
    The XML parser is listed in my code above. (and on the
    Thanks - I had read about LUA for my very early stages and had worked out that is what the HC2 uses - I was thrown by the JSON reference.
    I will carry on reading
