Hello! I want to buy a Yale Digital Door Lock  YRD220-ZW-619 from US. It will work with my HC 2 European version? Let me know! Thanks!
    It will have Z-Wave Module AYR200-ZWV-USA in package, but no-where is wrote MHz frequency it is working with.
    Please do check with the supplier if it do support Hc2 integration. In my country, my principle is currently selling the same model but only support vera for now.
    Guest fat
    The australian version of this lock does work for basic lock and unlock but no other functionality at this stage
    Guest chaicka
    I believe Fibaro has not added support for Yale YRD-220-ZW variants. Only basic lock/unlock is working from what I know. All other functions (eg. manage PINs) are not working yet.
    Correct. You can lock and unlock only up to 4.028 I haven't tried re adding it under 4.03x yet, but will try again tonight, as they are currently dead nodes on my system post the 4.037 update ...
    The most important is that the US version use the frequencies than the EU version, they are not compatible.
