hjelbak 0
Hi
I use a Relay switch 2x1,5 to execute some scenes in my house from a double switch. I have set it to "momentery switch" to turn switch on/ off on both switches, and want to ( in one of the scene's ) to turn off some ligths in the house by pushing it, but in block scenes I don't get the change state option. ( I get the "change state" in magic scenes ). So if the lights are "on" and the switch is "off" I have to push the button twice... When i look at it in LUA I see that it the state is "0" then the scene is executed, but how can i set the parameter to "change state" instead?
It looks like this:
%% properties
80 value
%% globals
if (
( tonumber(fibaro:getValue(80, "value")) == 0 ) <------- This is the parameter i want to edit to "change state" instead
or
then
fibaro:call(58, "turnOff");
fibaro:call(52, "turnOff");
fibaro:call(50, "turnOff");
fibaro:call(56, "turnOff");
fibaro:call(54, "turnOff");
fibaro:call(68, "turnOff");
fibaro:call(31, "turnOff");
fibaro:call(25, "turnOff");
fibaro:call(44, "turnOff");
fibaro:call(27, "turnOff");
Thanks!
-KH
4 answers to this question
