RGBW-controller with RGB-ledstrip (no white W)
How should I set parameters on RGBW-Controller to use it with RGB-only led strip. As it is now with parameters 1-14 it seems not to work with RGB only. (at least parameter 14 says 4369 which is for RGBW-strip).
5 answers to this question
I have mine set as RGB device .. or am I missing your question ??
I also then do not have a parameter 14
Cheers,
al.
Hi
I have just connected rgb strip using rgbw fibaro. I have problem with colours - it seems the green and red colour are switched. If I turn on red only  the green will actually turn on. And wise versa.
Any ideas anyone?
    make sure the order of cables are right. I think the fibre was out of order.
    Not sure what happened with the wires. Originally when wiring I have done associated colour of wires from RGB to RGBW Fibaro module.
    After your advise I have swapped the wires, reconfigured and all works fine.
    So beware the colour of wires can be wrong - I had to wire RED wire to green terminal and the same with GREEN wire to red terminal. Weird.
    Thank you
