Hello! I have few water sensors and want to install a Motorized Valve to turn off water in case of emergency. What valve will work with fibaro HC2 and a Fibaro FGS-211 Relay Switch?
Check this one:
It have 4 cables. It will work with Fibaro FGS-211 Relay Switch???
Please suggest. Thanks!
You need 24v transformer and this -
I have this valve and it can be used for water, gas etc. It works with the 3kw relay and it is normaly open so it will do the job!
