I'm having a problem adding back a RGBW device that I've previously deleted from my HCL box.
I deleted the RGBW device by clicking the x on the devices tab in the HCL interface on my browser rather than doing the delete device procedure. I assumed I then simply be able to re-add the device, clearly not quite right.
Since then I've not been able to add it back into my HCL system. I've tried:
resetting the RGBW device via B button.
Remove device by HCL interface
Add device by HCL by turning on power
Add device by HCL by manual inclusion B button
After doing all of those steps HCL still won't add the RGBW device.
So this morning I did a full factory reset on HCL (after taking backup). Even with a fresh system I couldn't add device back. I also interestingly couldn't add/remove any other (previous found & working) RGBW devices back to HCL.
What am I doing wrong?
Many Thanks.
