Doorbell with Universal sensor Help
Hi all,
I would like to achieve an actually simple thing:
Doorbell notification with a Universal sensor to my Mobile Phone.
What I did:
Wired Up the Universal sensor to Power
Connected Doorbell button as momentary switch, normally open
tried different scenes, but I simply cannot get a notification to my Phone.
Could someone please give me a hint?
I own a HC2, so also Lua scenes would be highly apreciated...
thanks
joystick
9 answers to this question
    Thank you, i did not know that there is a github repository.
    To be honest, i did not fully Understand the code, however it seems it Is very complex for my purpose.
    Isnt there a more easy Way to achieve a notification after button push on Universal Sensor?
    Cheers
    Joystick
    Or you can do like this
    Thats what i did, but i did not receive a Notifikation.
    Your Setting means"Breached", right? I also tried different settings, also a Magic scene with "open/close "
    Other hints?
    Cheers
    Joystick
    Other hints?
    Cheers
    Joystick
    Yes its Breached
    Oh boy!
    It is now working for me. It was neither a configuration nor a setup problem, but a Problem with my iPhone app that simply did not push the notifications!
    I deleted and reinstalled the app, and now everything is working.
    Cheers
    Joystick
    Anyone got a wire-diagram to accomplish this?
    In the Universal Sensor Manual, there is a Diagramm you can use for this Setup (doorbell button)
    Here you can find one.
