How to play a mp3 file in my sonos using LUA?
I'm using krikroffs vd for basic sonos and tts but miss this feature.
17 answers to this question
Hi KristioanO try with
    Thanks! I added the IP/port and changed the library. Added the complete code to a button. Still got this.
    [DEBUG] 07:15:13: socket status:
    [DEBUG] 07:15:13: socket err: Wrong arguments for overloaded function 'new_FTcpSocket' Possible C/C++ prototypes are: FTcpSocket::FTcpSocket() FTcpSocket::FTcpSocket(string const &,int)
    That's strange. See this yesterday
    Brian
    Yes, it's working! Just a stupid copy/paste error.
    Thanks a lot!
    Nice to have it confurmed. I spent a long time on the other copy tring to get it to work.
    Brian
    No, sorry i was jumping to quickly. Its not working... It was just running thru, but no sound at all.
    Debug:
    [DEBUG] 16:22:21: unMute sent
    [DEBUG] 16:22:21: Volume set: 20
    [DEBUG] 16:22:22: retry #0 action: Play
    [DEBUG] 16:22:22: play sent
    [DEBUG] 16:22:23: retry #0 action: GetTransportInfo
    [DEBUG] 16:22:23:
    [DEBUG] 16:22:28: STOPPED
    [DEBUG] 16:22:31: stop sent
    [DEBUG] 16:22:31: Volume set: 25
    This is my debug screen if it is a help.
    [DEBUG] 18:48:20: unMute sent
    [DEBUG] 18:48:20: Volume set: 50
    [DEBUG] 18:48:20: play sent
    [DEBUG] 18:48:20: TRANSITIONING
    [DEBUG] 18:48:25: PLAYING
    [DEBUG] 18:48:30: STOPPED
    [DEBUG] 18:48:33: stop sent
    [DEBUG] 18:48:33: Volume set: 22
    and this is the playfile address on a RaspberryPi
    playFile ("//RASPBERRYPI/sounds/gong.mp3", 50 );
    Hi Krikroff, thanks for the code. It works OK in my setup.
    However, compared wtih your TTS VD I have noticed a couple of different behaviours:
    1.- Playing is limited to 20 secs (10 loops x 2 secs), and after that, stop is sent. That should be long enough for a TTS static message but I'm wondering why the TTS VD based on the toolkit seems to have the same code (limited to 120 secs) but never stops.
    2.- Function getCurrentTrack is not implemented and therefore the music beeing played when the TTS is activated never returns afterwards. Will you add this functionalty?
    Thanks.
    Debug:
    [DEBUG] 16:22:23:
    KristianO, it seems that the path or filename you are trying to play is wrong, because the HC2 is not reaching it according to your debug messages. Check it and include full path and file extension (.mp3 or whatever)
    Thanks! Yes it seems like it. I have a OS X server running and think i have 2 options. The file sharing or to locate the file via the web server.
    I have tried both wo success. Any idea how to type the directory?
    eg. if the file is located at my server "IP_adress/Home/dogs_barking.mp3"
    Try "//IP_adress/Home/dogs_barking.mp3"
    Thank you Krikroff for another fine piece of code. My favorite part is urlencode()
    Brick: Tried that but not working... the log is different but still no sound.
    playFile("//10.0.1.10/Home/dogs_barking.mp3", 25);
    [DEBUG] 10:15:11: unMute sent
    [DEBUG] 10:15:11: play sent
    [DEBUG] 10:15:11: STOPPED
    [DEBUG] 10:15:16: STOPPED
    [DEBUG] 10:15:19: stop sent
    I can connect to the IP and locate the "Home" share wo usr/pwd.
    Can you find and play the file from Sonos app?
    Problem solved:
    - Computer name = WINS name (Case sensitive)
    - Define Share with guest access
    Good to know.
    Now let's hope that Krikroff adds on the return-to-previous-track feature...
    I implemented this code with some tweaks. Love your work Krikroff!
    Works a charm other than every now and then the track being played is truncated and I am not talking about truncation after a long period of time. All my files are short ie less than 8 seconds. Sometimes the file gets a couple of seconds through and then stops playing. Has anyone else experienced this?
