Hi guys,
Can somebody suggest me a way to stream audio in all rooms and in the batchroom as well? As far as i have searched in the forum the SONOS speakers are a solution but very expensive... What about the Dlink WIFI -
We can connect to the existing ceiling speakers and power the speakers and the dlink via Fibaro 3kw or 2x1500w relay. So when you want to listen to music just turn it on, but what about the HC2, does it support air play?
Any idea is appreciated!
You can try this:
    You can try this:
    What about the HC2 compatibility?
    It works with a virtual device.
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> have one in my bathroom.
    Please give more details aabout the used commands on pm.
    It is an interesting device. What kind of speaker are you using?
    Thank you in advance!
    I will write you a pm
    • 4 weeks later...
    why pm?
    I don't think pm is a good point. This is a forum for sharing information. Please share your information in order that all people can learn.
    Thanks to all
    Sonos is still the best bet I guess, though it is very expensive. I have been opting for Airplay, but it really isn't as nice as the Sonos systems. My only problem is that I am into my Airplay speakers approx. €3000 so I don't really want to convert to Sonos all through. I have made something which is sort of working, but it requires quite a bit of coding and knowledge of Apple scripts and it will only work if you own a Mac.
    Sonos is the only system (to my knowledge) which creates it's own private network which isn't affected by other wifi products as it is the case with Airplay or similar.
    • 4 weeks later...
    I using Rasberry with aditional DAC converter + Sqeezeserver. Evrething cost 60 USD + speaker price. I can control it from Fibaro, in scenes ... can lauhch XBMC too.
    Squeezebox here with some original and some raspberry.
    When plugins available I have an almost working squeeze plugin for hc2.
    @robmac what kind of speakers do you use for the raspberry?
    A mix of Acoustic Energy Active, Dalli, KEF and B&W.
    Various amps from old linn klout to these little wonders
    All amps switched on and off by HC2 when music starts playing/squeezplayer is powered on / off using switch modules
    • 2 months later...
    robmac, whan are you planning to release your plugin??
    I can see you are the only help for SB fans
    cheers,
    naboo
