Problem with variable and timer
lsguotti
Dear all,
I need your the community support .
I'm trying to configure the HCLite  to open my roller in the morning only when I'm not in Holidays.
I can not use the LUA because I have the HC Lite, I tried creating a variable that indicate when I'm in vacation and when I'm going to work and I test the variable before the timer. This solution in general working well, I have the problem when I change the variable value from holiday to work because if the roller is closed the system open immediately the roller and ignore the timer condition.
Someone could you explain me the reason or do you have any idea to solve this problem?
Thanks for any suggestion.
Luca
Scene
Hi
Make sure that the variable is not selected under "Triggering variables". This will trigger the scene to run regardless of time.
great tip, they should put this in the manual.....
never mind, there is no manual
