Vitrum double switch + HC2
Smartelite
Hello guys
I have VItrum double switch which can be configure either push button or switch ON/OFF
With ON/OFF both buttons are working well with HC2
But when i configure on of the buttons as push button, there would be some problems especially with the common.
Anyway, my question is can I change the "ON/OFF" template to the "Dimmer" template of the device?
10 answers to this question
Are those switches easy to add to HC2? Do you have just to turn on/off to add them to the system?
  • Yes they are easy to be added. but they are added as three devices.
    Vitrum switches come with the feature that you can change from switch to push button, But this is not reflected to the HC2
    hi
    I have Vitrums myself...
    Can I ask you what you mean by 'Vitrum switches come with the feature that you can change from switch to push button"?!
    Tnx
    Peter
  • I have read in the technical sheet of Vitrum that you can configure the switch to either switch or button
    while configuration |flashing Red| or |flashing Blue|
    I have 4 time a Vitrum 4 EU Zwave switch (blue, green, yellow) and 1 time a Vitrum 6 EU Zwave switch (blue, yellow)
    Have a lot of questions about these products actually.
    I tried yesterday to generate the template data (like Fibaro is asking in the latest firmware) for the devices too but this doesn't work either.
    Searching for a guru
  • I tried the 6 Button EU Vitrum switch it is working well.
    It needs some more integration with HC
    If you need any help with Vitrum just let me know
