Block Scene (GPS) not correctly translated to Lua
Hi all,
I read a lot about the family location feature wich does not seem to work properly.
I figured out that, when I setup a Scene using Blocks and switch it over to LUA the code is not translated correctly. The "then" arguments are completely missing.
see the attached screenshots.
Is this a known bug?
Cheers
joystick
it is not connected with GPS. At this moment block scenes doesn't support thermostat set points. It is reported to our developers as an improvment, and will be added in future to our system.
Jacek.
Guest Lode
Yep, i noticed that bug.
But what do you mean by in future ?
Next update, new version, 1 month, 1 year ?
Please explain, i really need this.
Hi Lode,
Have you try creating a lua scene and input the setting of thermostat points yourself using lua coding?
