The scene is not performed continuously.
Guest pablotibis
I have this scene that I copy below it takes to send a push when the washing machine has finished its work, the problem is that for some time (I think somewhere update) does not work anymore, if I Start from inside the scene works and values correct, but by itself does not work, it is as wrong in loop to continuously monitor the consumption value of the washing machine. Any idea?
%% properties
53 valueSensor
%% globals
-- Cambiare id 53 per il dispositivo da monitorare
local power = fibaro:getValue(53, "power") -- unità da monitorare
local LavaOn = "LavaInEsecuzione" -- creare la variabile LavaInEsecuzione
local LavaFerma = "LavaFerma" -- create a variable with name LavaFerma
local push = "LavaPush" -- variable for push
if (fibaro:countScenes() > 1) then
  fibaro:debug("TROPPE SCENE");
  fibaro:abort();
fibaro:debug("HC2 wash script stated: " .. os.date());
fibaro:debug("Consumption="..power.." Watt")
if (tonumber(power) > 100) then  -- change to wanted value in watt
    fibaro:setGlobal(LavaOn, "1")  -- sets variable to 1 if machine is running
      fibaro:setGlobal(LavaFerma, "0") -- sets variable LavaFerma to 0
      fibaro:setGlobal(push, "0") -- sets variable push to 0
      fibaro:debug("Lavatrice funzionando")  -- lite debug text
elseif (tonumber(power) < 3) then
  fibaro:debug("Lavatrice non sta funzionando.")
  fibaro:setGlobal(LavaOn, "0")
  fibaro:setGlobal(LavaFerma, "1") -- Lavaggio completo!
if (tonumber(power) < 3)  and fibaro:getGlobalValue(LavaFerma) == "1" and fibaro:getGlobalValue(push) == "0" then
  fibaro:setGlobal(push, "1")
  fibaro:debug("Send push message")
  fibaro:call(151, "sendPush", "La lavatrice ha finito alle: " .. string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min));
  fibaro:call(152, "sendPush", "La lavatrice ha finito alle: " .. string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min));
Change valueSensor to value...
Guest pablotibis
    Hi boomx, I did not understand very well, tell me if I have to change as you see below:
    %% properties
    53 value
    %% globals
    only in this part of the scene?
    I think it should be
    53 power
    That's what I use for some scenes at least.
