Fibaro with Cross switch
Hello, first of all , sorry for my bad english.
I have a problem regarding connecting fibaro relays with cross switches. I have 5 switches in the one room and each can turn light on/off, and I dont know how to connect Fibaro's relays. I tried with 1x3Kw, 2x1,5KW and Dimmer, and no success. When some switch f.e is ON I can't turn off light via Fibaro.
Can anyone please help me ?
Best regards
5 answers to this question
Guest fat
It may be best to use momentary switches in this instance. Run a common live between al switches and a common switched live between all of them and connect the switched live into the s1 on a relay or dimmer. Make sure that momentary switch is selected in parameters and it should work
    Thanks for answer dude !
    by saying "it may be best to use momentary switches", do you mean psihically switches, to change these toggles to momentary - tasters or ?
    I will try to edit parameters
    Guest fat
    Change all switches to a momentary (bell press) switch. If you use a dinner these will also let you din lights by pressing and holding the switch in
    Thanks dude, I listened your advice, and it works now, I replaced switches with momentary, changed parameters and thats all.
    I'm very happy about this, I owe you a lunch
    /emoticons/default_icon_idea.gif" alt=":idea:" />
    Guest fat
    Glad I could help
