I installed an FGS221 (Dual Relay Switch) with a monentary switch and set parameter 14 to 0.
The problem is that the FGS221 recognizes a single button press as two or more. The switch bounces.
It stays off then.
It only works when I press the button very short.
Is there a solution for that?
Quax1507
Are you talking about the hardware only, I mean switch-relay-lamp? Or did you "include" the relay and are there any scenes on your HC2?
    The relay is included into Razberry but the issue happens in "switch-relay-lamp", too.
    Change the parameter 14 switch type to the same as your manual switch? Be it a momentary or toggle switch
    It is a momentary Switch and Parameter 14 is set to 0!
    Odd one... doesn't ring a bell and I've been around for 2 years here... Let's try some shots in the dark, they sometimes hit something
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> First, I'd exclude it from the Raz then reset the relay. The safest way to do that is by removing mains from the relay, pressing and holding the B button, connecting mains voltage to the switch, keep holding B button for 3-5 sec. then releasing it (it's in the manual, but in other wording). Now it should work without controller but with a toggle switch. If this works as expected, I'd include it and set parameter 14.
    Thank You! I will try this in the next days and let You know!
