Can someone clarify for me; I'm using HC 4.040 BTW.
This relay can switch 2 loads so it is realistic to assume those 2 loads are different energy consumption.
So why on the ADVANCED tab in HC2 for the device can I only set a common power usage for both loads; surely this is limiting and I should be able to set a different load for each?
Julian
Hi, the power consumption should be declared on each slave devices and not on the master. You should go into the advance tab of each device and set the power consumption that you need.
Hope it will help.
Regards
    Thanks.  I think I was confused because it seems to default them all to the same first value that is set but I see I can then change the individual slaves to their own settings.
