Virtual Device - GetVolume - DNLA
I have a Virtual Device from which I want to get the volume of a dlna-device. I use the following code:
But I get an error, if I use the code:
[DEBUG] 22:22:19: HTTP/1.1 400 Bad Request SERVER: Linux/2.6.32.27, UPnP/1.0, Portable SDK for UPnP devices/1.6.6 CONNECTION: close CONTENT-LENGTH: 50 CONTENT-TYPE: text/html
400 Bad Request
Maybe somebody could help me with this. I have no other idea
9 answers to this question
    nobody?
    Just a thought, didn't try this...
    With 0x0D0x0A0x0D0x0A you want to send an 'enter' command right?
    Remove this from your payload and add
    and change:
    to
    As I mentioned, it's just a thought....
    I try your idea... Thank you. Still the same error:
    [DEBUG] 13:45:19: POST /upnp/control/rendertransport1 HTTP/1.1 Content-Length: 500 SOAPACTION: "urn:schemas-upnp-org:service:RenderingControl:1#GetVolume"
    [DEBUG] 13:45:49: HTTP/1.1 400 Bad Request SERVER: Linux/2.6.32.27, UPnP/1.0, Portable SDK for UPnP devices/1.6.6 CONNECTION: close CONTENT-LENGTH: 50 CONTENT-TYPE: text/html
    400 Bad Request
    Maybe the error is the content-length. But I don't know how to count it.
    Google it there are plenty of cut n paste string calcs online
    Or you upload the working rocki-vd
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> I asked you via pm
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> would be nice
    Maybe you can change content length 363 to 405?
    Get it
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> thx for your help...
    Okay, you count only the real content instead of everything, what I Did...
    Learning all the time...
    Yes, that was it
    /emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Good to know for the future...
