How come push works sometimes?
My HC2 is still on 3.6 and we have two iPhone connected with it.
My wife has an iPhone 5S and i have an iPhone 6.
Have had some trouble with push notifications since the version that did just that.
But now my wife ALWAYS gets notifications and i get them sometimes, how can that be? I would understand if i never got them ...
It's no difference if i'm on the local Wifi or mobile connection ...
Tried erasing app, reinstalling, disconnected & reconnect to HC2 ...
Any suggestions?
10 answers to this question
Type "push notification" in the search field at the top and you'll go crazy. But I'll summarize it for you. Anything from using 3-rd party apps to dancing around the HC2 three times (make sure to start in the east!) has been suggested. I never saw something repeatable. Not for 3.X and not for 4.X
    I've read quite a bit about it earlier, but what i don't understand is how it can work sometimes and sometimes not without anything being changed in the setup??
    Once again i tried to delete my device from HC2, erased the app, reinstalled and reconnected. Changed scenes to the "new" device. Worked three - four times with push then no more ...
    My wife's work all the time ...
    iphone 5s vs iphone 6.
    Is the fibaro app same version on both mobile?
    Yep, same same! I get push sometimes, my wife always! Since the command to send push to the two phones comes after each other in the scene i was thinking if the HC2 sometimes misses to send to me due to some kind of conflict when sending two push after each other?
    I recently found out that Push works fine when not connected to my WiFi... On WiFi it doesn't work... Strange... Using a iPhone 6+...
    I have the same issue as this but the other way round. I get push notifications but my partner does not.
    When it was setup, worked ace for a few days and then just stopped on her phone totally!
    Removed and reinstalled the application, created a new user, changed the scripts to support this and still no joy.
    We use the push notifications for when doors are opened and closed, fire alarms and doorbell using a fibaro windows contact sensor.
    well, I Just upgraded phones with work to an i6, not brilliant, push doesn't work at all.
    It was working for me on older 5.
    One thing, how do you allocate a phone to a user though ?
    For instance, how does HC2 know who belongs to which phone in the list ?
    What am I not remembering to do, .. ..
    Cheers,
    al.
    Cheers,
    al.
    I think it's done thru Access Control. The phones are listed there.
    Yep, thanks Raj, but it was more a confused question which I'm now nutting out ..
    I think what I should ask is  ;
    How do I find the iOS device number to push to ?
    I can push as many messages as I like now with a simple test script and want to try the others .. although it has just dawned on me I can block script the user numbers easier and utilise them in lua script .. too easy.
    fibaro:call(PHONEID not person id, "sendPush", "This is a test message !");
    Nothing to see here, other than ' thanks Raj '
    Update : I can push to all my i devices, under a variety of versions, both jailbroken and stock, on wifi and on 4g ..
    I just found the phone to push to by using blocks to get the number for each i device (not user which I initially thought it was) .. as i didn't have krikoffs toolkit installed here.
    so far .. all have asked me what i'm playing at .. so it must be all good ..
    Edited by alandee
