I have a HC2 with latest software update - Using 4 x 2x1.5Kw relay switches to control irrigation.
Using the web interface I can manually switch on the irrigation for a period of time or off again and the icon shows the status accordinbgly.
If I try and switch it on from within IOS (iphone)  it temporarily switches on and the icons then shows that it is off again. However the sprinkling system just stays on. Only way to switc h them off again is via the web interface
Any assistance with this problem?
