I want to use the 'power off' function of the FGS221 Switch 2x1,5kW. It is version 1.4 and if I enable this function I can set the time to max 2,55 seconds (seems the used a byte to store the value).
Another FGS221 Switch 2x1,5kW I have is version 2.1 which has a max of +/- 65000 (unsigned 16 bit integer).
Is there any way to fix this issue, or should I create a snene?
THanks
The official documentation confirms this behavior. I don't have a FW 1.4 but I do own several FW 2.1. These units are not firmware upgradeable, so you'll have to use scenes instead of the builtin timer.
    Thanks, wrote a scene and its working great.
