Limit Value for Slider in Virtual Device
I am trying to put a Virtual Device that allows me to boost the heating in the house from 1 hour to 10. However, the slider has values going from 1 to 100.
Is there a way of limiting the range for slider to 10? I will for the time being read it and divide it by 10 to get me there but a 1-10 would be a better solution for me.
If anyone has a Virtual Device that they have already setup, if you can share this, then it would be great.
Raj
Did you find out how to limit the range on slider? I also need this =)
You can use operator modulo to calculate whatever range you need taking as an input the slider value 0-100
eg.
place the following in the slider definition :
local suwak1 = 9+fibaro:getValue(fibaro:getSelfId(), 'ui.Slider1.value')
suwak1 = (suwak1/10 - suwak1%10/10)/10
the local variable 'suwak1' will have one of the the values    0 , 0.1 , 0.2 , .... , 0.9 , 1    depending on the slider position.
You can calculate to have whatever range you need and to skip fractions if you need.
Tnx I'll give it a try :-D
Edited by freespirits
