VD stops working after 3 - 4 Hours..
I have a VD that checks status of a Fibaro Door/Window sensor and its working fine for a while but suddenly it seems that the http request wont get an answer and the VD stops working.
fibaro:debug("Checking Status..")
VD = Net.FHttp("192.168.2.85",80);
VD:setBasicAuthentication("user","password");
response ,status, errorCode = VD:GET("/api/panels/event?last=1&type=id&deviceID=699");
fibaro:debug("Received answer.. trying to decode it..");
Everytime it has stopped, the last thing i see is "Checking Status"..
Any ideas?
BR
7 answers to this question
I have exactly the same with below code in the main loop (no code elsewhere).
2-3 hours and then stops without any errors. On the debug screen it just shows up to latest check.
Restart home center and it works for another 2-3 hours....................
--Router Connection
router = Net.FHttp("192.168.1.1");
router:setBasicAuthentication("username", "password");
response, status, errorCode = router:GET("/DEV_device2.htm")
--Check TH Presence
if(string.find(response, "E8:B9:D0:1A:E0:C4")) then
 fibaro:setGlobal("PresenceTHHome", "Hjemme");
 fibaro:setGlobal("PresenceLastSeenTH",os.date("%H:%M", os.time()))
 fibaro:setGlobal("PresenceStatus", "Hjemme");
  fibaro:call(105, "setProperty", "ui.Label1.value", "Hjemme")
  fibaro:debug("Tor H Hjemme")
else
 fibaro:setGlobal("PresenceTHHome", "Borte");
  fibaro:call(105, "setProperty", "ui.Label1.value", "Ute " .. "siden " .. fibaro:getGlobal('LastSeenTH'))
  fibaro:debug(" Tor H Ute")
fibaro:call(105, "setProperty", "ui.Label4.value", os.date("%D - %H:%M", os.time()))
I have the same error with a VD. Make a workaround and put my code of the main-loop into a button and make a scene, which pushes the button every 2 seconds (In main-loop it runs every 3 seconds). Works good for me.
    Yesterday i copied all code inside this VD, deleted it, made a new VD and paste the same content.
    Its been running for 14 Hours now so it seems it did the trick..
    And now it has stopped again.. When it worked i had forgot to update the correct VD ID when i update the setProperty, ui.label.value.
    Tortho: Can you temporary remove all setProperty value and only use fibaro:log to update info on your VD?
    Just to see if it works for you also?
    BR
    I had this problem to when i had it in main loop.
    Put the code in a button and make a scen that presses the button, and maby your problem will be solved.
    My new code below. Just restarted, will let you know.
    sonnyboy,
    It might help, but thats not what it is supposed to be
    --Router Connection
    --Check TH Presence
    if(string.find(response, "F8:A9:D0:1A:E0:C4")) then
     fibaro:log("TH Hjemme");
    --  fibaro:call(105, "setProperty", "ui.Label1.value", "Hjemme")
    else
     fibaro:log("TH Ute");
    --  fibaro:call(105, "setProperty", "ui.Label1.value", "Ute " .. "siden " .. fibaro:getGlobal('LastSeenTH'))
    fibaro:sleep(2000)
    Hi, It worked for about 4 hours, and then it stopped, so no difference between set property or the fibaro:log..
