ZME_WALLC-S + Fibaro Roller shutter
Hello All,
Iam totally new in this.
I have an Home center 2.
Now I have installed an ZME_WALLC-S and a roller shutter to my awning which is equiped with an somfy motor.
What i would like to do is that when I push a bottom on the ZME_WALLC-S then the roller shutter shall start and the sunshade should go out.
If I push Another bottom then it should go back in again.
I dont understand how I connect these two togheter?
Antoher thing is that when I installed the roller shutter it wanted to make an calibration.
But when I do the calibration then the motor continues runing and the textile for the sunshade goes out, when it is 100% is continues and rolls up the textil in the wrong directon.
Does anyone have know how to fix this?
Thanks in advance!
Hi
did you solved this? i have similar issue to control separate device (1x3KW module) if i press II on the roller shutter. In fact i have two devices roller shutter and 1x3KW module. up and down buttons working ok, but when i press II on the rollers I need to activate separate module. i am using HCL
thank you
    No I haven't, At the moment Iam trying to find a Company in Sweden who can program this kind of system.
    I need the ZME controller to be connected to the roller shutter.
    The zme controller is connected to the HC2 and also the roller shutter, but to link them togheter is to difficult for me since I don't have any giudeline for this.
    Maybe there is someone out here who can help out by remote for a small fee.
