Is it possible to setup FGS221 as a device to control Heating and HW? I have it wired to switch the heating/hw on at the moment. It works fine but in the device setup, it does not have heating/hw as an option in the dropdown.
I am also confused as to how the heating panel would work in my setup. I have quite a few temp sensors in the house which report the temperature back to HC2 but I am not able to setup a heating panel.
Depending on what you are trying to do you can link a relay to a temp sensor in the linked devices panel. You assign the linked device to the room that you want to control heating in and then in the heating panel you setup a room/zone with desired temperatures and make sure to check the box for the room from above. That's how my heating is setup. It works fine when it's working.
    Thanks Aleks.. just tried to do this. But I cannot add the linked device it into my heating panel as it is not shown in the Rooms to add.
