All my rgbw dimmers are becoming dead nodes all the time.
And also if i use the web gui and press on on a input it doesnt react i have to dim to make it react.
That means i cant use "ON" in programming.
And even if i could it doesnt matter as they are all dead all the time.
When will this be fixed?
why do you think it's broken??
my rgbw dimmer just works fine on 4.40
cheers
emiel
having the same problem. the RGBW module goes dead on its own all the time.
Dead nodes can have multiple origins, since RGBW can create heavy traffic in Z-wave you should consult support in that matter.
