Last night one of my FGS-221 stopped working, all of a sudden. I disconnected it from mains & reset multiple times to no avail. Also tried reconfig, both soft & hard, but neither of those changed its status.
I replaced the defective unit, but now I've got a dead 'not configured' device in the web interface, with a warning to configure it properly. Trying to delete it does not seem to work...
So my question: Is there a way to completely delete such a 'phantom' device from my working configuration?
I'm running HC2 4.040, Zwave version 3.67.
Thanks!
Frederik
I have the same config as you and I have the same problem, but it is with a Fibaro Dimmer and a Fibaro Flood Sensor. I deleted them the proper way, but they would not remove themselves. They have been dead for a week now, but I can not delete them no matter what I do.
I guess it's a bug in the current version.
    Thanks, Aleks.
    The other strange issue I've noticed is that there now suddenly seems to be a delay when I operate my device via the HC2. Could that be related to this device still being in the config but no longer responding?
    Frederik
    similar to
    and others.
    a couple of which are acknowledged, so in the fix cycle..
    cheers,
    al.
    Same for me, fixed in the next version
    Waldemar Kin 09 Apr 15
    Dear Sir,
    Unfortunately this deleting option will be fixed in next software hot fix version.
    Sorry for inconvenience.
