Hi all,
I bought a Fibaro Relay (1x3W) and I am trying to set it up with light spots which can be controlled with three different wall switches.
Is it possible to integrate the Fibaro relay in this setup?
Marco
You can simply connect the Relay Switch S1 to the wire the load was connected to and choose it to be activated by change of state of input.
    Sorry but it is not clear to me.
    I have three switches which are controlling a series of LED spots.
    How should I integrate the Relay Switch?
    I want of course integrate it only on one wall switch, not in all of them.
    Ok, when you mentioned three light switches I thought it was about controlling relay by all three of them. If you are now controlling the lights by 3 switches, there is no way of separating just one of them to control Relay Switch and keep others 2 controlling light independently - circuit would need some rearrangement.
    Marco please draw a picture to explain what you want to do. Do you have 3 switches controlling the same lights or 1 switch controlling one light?
