Can not remove LC13 Thermostat
i can not delete my Danfoss LC13 Thermostat. When i use the remove device function, it tells me device removed, but it is still there. WHen i click delete device in device view, it is gone but reappears on browser refresh.
Now i already have 3 of the same device added under different IDs and can not delete the dublicates...
Removing the master module first does not help either... Swapping the room and then delete them does not work.....
greets
I have the same problem by with a different device.  Did I see somewhere that this problem is acknowledged and they are rewriting the deletion logic.  I hope we can get an update to 4.040 soon to fix this.
    Good to know.thx
    There is indeed a problem with deleting devices, we are aware of that and working on a solution.
