FGSS-001 get different alarm values.
Guest azevenhuizen
Is there any way I can get hold of the different alarm event of the Fibaro smoke sensor.
For example, is there something like, fibaro:getValue(101, "value"), where 0 is no alarm, 1 = smoke alarm, 2 = tamper?
Also I can different sensor statuses, but can someone explain what the exact difference is?
Sensor can be 'On/Off' or 'Opened/Closed' or 'Active(Breached)/Safe'
Cheerz,
Arno
Hi, in v4 the statuses in block diagrams are corrected, so only valid ones are displayed. Also you have possibility to check other fields in the API, by simply replacing "value" with proper one.
Guest azevenhuizen
    Thanks for your reply.
    Unfortunatily I had very bad experience with v4 and I am a bit frightend to upgrade.
    Guess I will have for a while with my fire alarm, to have a stable v4 in this case.
    Cheerz Arno
