XiteHosting 0
Since the Qubino dimmers are supposedly better in handling LED bulbs, but the Fibaro dimmer allows me to have 2 buttons with sceneactivation, I wanted the best of both worlds.
I connected two momentary switches to the fibaro dimmer.
I attached the LED bulb to the Qubino dimmers.
I added the Qubino to Association Group 2 on the fibaro dimmer.
When the bulb is connected to the fibaro, it lightens up slowly, so I have time to release the button at the wanted dimming level.
When it's attached to the qubino, and I try to control it from the fibaro, the light goes up too quick, so I don't have time to choose anything between off and on.
I already changed value 66 (dimming time) on the qubino to 60s, but this doesn't seem to change anything.
Is there something I can change on the fibaro side?
2nd question. Is the qubino really better? I had to change the maximum dimming value to 45, as there was no difference between this value and max value.
On the fibaro with the bypass attached it behaves exactly the same as on the qubino with the max dimming value.
Both have no flicker, and great dimmable range. I'm using a Philips 6W dimmable led bulb.
thanks for reading,
Stijn
