I planned to control my projector screen by using the roller shutter module. Unfortunately the wiring looks different than expected...
My projector screen has a control box, which provides 3 buttons (up, down, stop) and a receiver for the RC. I thought it should be simple to connect the Roller Shutter module between the control box and the screen motor.
The cable from controler box to the screen has 4 wires:
- Black
- Brown
- Blue
- Yellow/Green (Ground)
Dependent on the situation I can document the following details:
               off                        down       up         off
              (upper position)                                 (lower position)
Black      power                   power       power    power
Brown     n/a                        power       n/a         power
Blue        power                   n/a            power    power
It looks like the motion is controlled by Brown and Blue, but why do I have additonally a Black wire which provides constant power? I also don't have a Neutral wire. I'm confused.
Please help. How do I need to connect the Roller Shutter?
Thanks,
Klaus
Please take  a look  here.
Maybe, if cinema screen uses 24V, you should use  2x1.5KW Relay (FGS221) module instead of roller shutter module.
Hi
i same similar situation and need to activate separate device module through II command on the figaro roller shutter. If I press II command it sends z-wave command to the panel. How to use this signal for activating 1x3KW module?
