Virtual devices in scenes
Dear experts, help the beginner. There is a device:
To it is attached to the module 8 relays. Added in virtual devices at each relay.
Device (button) works.
But when I try to create a scene in the list of devices virtual devices do not appear to select, only available sensors z-wave.
Tried to roll back the firmware, remove all devices - nothing helps.
Sorry for my english
4 answers to this question
You have to choose some value as a trigger and condition and then you will see possibility to choose virtual device button as an action
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
    Thank You very much. It works
    hello,
    is it possible to trigger virtual devices in scenes using the home center lite ?
    i can't see my virtual devices when i build my scene.
    Yes, it is possible. Post your scene please.
