Scene to activate lights after 1.00 AM
I would like to know how to program in LUA to activate a light (through wall plug) when a movement is triggered by a PIR (motion sensor) after 1.00 AM. I presume this is a really simple thing, but I don't know how to program this.
6 answers to this question
if (motion sensor is breached) and time is after 1.00am
then
activate a light
Guest fat
I use a global variable to set morning, afternoon, evening and night times. After this code motion sensor to activate only if night time global variable is set
Or just use code converted in blocks to check the time range.
    Could you please mention an example for these global variables?
    Guest fat
    The global variable I have is morning, afternoon, evening and night. When sunrise hits the variable changes to morning. Midday sets the variable to afternoon. Sunrise sets global to evening and 10pm sets the variable to night
    I use the variable to trigger a light scene that is "If variable=night and motion sensor=breached then turn on light at 10% brightness for 90 seconds
    A Lua scene is created to set the variable and then I have used a basic block scene to control the light based on the variable and motion trigger
    I use this Lua Script:
    Edited by j.nowacki
    Please use code tags
