Acho 2
Hi I need our help ( Im new to Lua/HC2 )
Ive created VD to operate Aircon via Globalcache, and Id like to add into each of the buttons of the VD a "string" to set certain variable - So if I press "Heating 20C" button, the variable should be set to "H20" - I have no clue how to do it
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />P.S.: The buttons so far are not in lua neither - do can you pls also advise how to chnge them into lua ? Basicaly the command is use so far is:
sendir,1:1,1,38554,1,1,367,171,21,65,20,23,20,23,20,23,20,65,20,23,20,23,20,23,20,23,20,23,20,23,20,23,20,23,20,65,20,23,20,23,20,23,20,65,20,23,20,66,20,23,20,65,20,23,20,23,20,65,20,65,20,23,20,65,20,3800,0x0D0x0A
Thanks a lot
4 answers to this question
