trying to push to multiply foons
Hello
i have a script that i want to push to multiply foons
i thought this will work but it doesn't
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
local today = os.date("%d %B");
local timenow = os.date("%H:%M");
  fibaro:debug(today.." "..timenow)
local
  phone = 537,538,539
  Time = "17:46"
  test = "19 April"
if
  today == test and Time == timenow then
  fibaro:call(phone, "sendPush", "Test")
  setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
   tempFunc()
   tempFunc()
only the first phone gets the message
if i change
phone = 537,538,539 to phone = {537,538,539}
then nobady gets something
Have you tried breaking the push loop into 3 and removing the variable to see if that is the problem?
I've not tried pushing to multiples, just always have them in a separate loop.. this would be neater though !.
Anyway, it will help tell you if the other phones are able to receive push as a straight push should work.
cheers,
al.
