johnd 0
Hi all!
I am a bit of a newbee to LUA so have been reading/stealing a lot of good things from this Forum. Thanks to all contributors for that!
I have just installed my garage door to be controlled by a Fibaro switch. It works great but as I have no sight in HC2 to whether the garage door is open or closed (it is a simple trigger open/trigger close door) I would like to disable the device with the start of the virtual device Away/Holiday (that also sets a predefined variable.). By disabling the garage door device I won't have to worry about accidentally opening the garage door when away.
On the developer forum I did find some code that should be able to this but can't seem to get it to work:
function Device:setEnabled(true)
For one, I don't know what to fill in for Device. ID does not seem to work.
The system also accepts the code below but I does not seem to do anything.
fibaro:call(67, 'setEnabled','False')
Can someone tell me what I am doing wrong? Thanks!
