Sunset scene suddenly stopped working.
Can anyone tell why this won't work?  (I have cut and pasted this from the LUA view of the block scene).
I simply want variable lightsactive to be active 40 mins before sunset. It used to work ok until a couple of weeks ago!
Edited by j.nowacki
Please use code tags in the future and adjust your code to be more readable
I would suggest adding some debugs in Lua and checking if code runs properly and enters the condition responsible for checking hour. That way we can determine if there is problem with communication with this particular device or the code.
    Thanks, I understand your advice but have always used block scenes and not yet ventured into LUA.   As the HC2 says "switching back will not be possible"
    Maybe I need to start learning!
    I can send you a working script. You can pm me, if you want
