I have an Itach ip to serial converter. I need to be able to send out serial commands to control various AV equipment. The Itach comes with a test application, and the serial commands that I use, work.
In HC2 I create a virtual device, use the right IP and port (4999 for serial 1). When I create buttons, and add the serial codes there, it does not seem to work. Does anyone have a clue on how to do this?
The serial code is !1PWR01, which works in the ITach testapplication. I tried it with the carriage return:
!1PWR01
0x0D
But nothing happens..
4 answers to this question
Can you try append to end of string "0x0D0x0A"?
    /emoticons/default_icon_biggrin.gif" alt=":-D" />  it was that simple.. thank you very much. Now see how to get the status results back
    Its possible, but you need migrate to LUA script.
    Example (for sending command to Z-Wave API). Only rename variables, put your ports and IP, and new data for GET request
    Great, thank you! I will experiment with this a.s.a.p. Do you have any idea on how to add spaces to rs232 codes? My cd player needs "W 1 1" as code, which works in the Itach testapplication. But I cannot get it to work with the HC2....
