FOSCAM FI9821Wv2-B HEP!!!
hello can you tell me what parameters I have to run away INSERT for the camera
FOSCAM FI9821Wv2 - B
I can not
THANKS
5 answers to this question
Please be sure to upgrade the camera to latest firmware
After the firmware upgrade then enter this command from a browser:
http://CAMERA_IP_Address:CAMERA_PORT/cgi-bin/CGIProxy.fcgi?usr=admin&pwd=xxxxx&cmd=setSubStreamFormat&format=1
(this will enable the MJPEG stream, by default only JPG and H.264 are enabled on this camera.)
Then add the device to your HC2/HCL:
Advanced settings:
Leave the User & Password empty.
IP Address (including port if needed): xxx.xxx.xxx.xxx:xxx
JPG path: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=xxxx
MPJG stream path: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=admin&pwd=xxxx
Turn left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=admin&pwd=xxxx
Turn right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=admin&pwd=xxxx
move up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=admin&pwd=xxxx
move down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=admin&pwd=xxxx
Stop camera movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=admin&pwd=xxxx
Display camera image at Your House, advanced options: JPG, refresh time : 5
    all ok tanks!
    everything works well only if you move the camera with the buttons for moving the camera makes all the spin and I can not stop it ! fifths of the meeting or any right or all left ! consa same for inquiries concerning high and low !
    is there any solution ?
    Advanced settings:
    my problem is instead the following are able to set the camera worked great for a while but when I connect remotely ( because locally it still works well ) I get the camera image then disappears why?
