When will user's plugins come back?
4 months passed since the functionality completely destroyed by Fibaro.
It was withdrawn due to security concerns, as far as I know it was switched to higher priority recently, I assume in one of nearest updates this feature will be re-enabled.
Thanks for clarification. Then we just need to wait
  • 1 month later...
Ah that explains it - sure I saw them in passing once. Then when I wanted to actually have a crack i couldn't find it in the UI!
Not going crazy.... just yet.
  • 3 months later...
Guest gembrain
So nearly 5 months on?
Is it coming back soon
  • 1 month later...
What is happening here ? Any news on the plugins?
  • 1 month later...
2 months later, whats the status? Any indication?
No response still means they obviously are nowhere near implementing it yet. Unless they really are that rude to not answer such simple questions?
We want have stable system on both devices first (HC2, HCL) and later we gonna add plugins system with many improvements
Appreciate the response guys! Good idea!
Good feedback, thanks.
  • 5 weeks later...
How i could do with this functionality RIGHT NOW
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> need to be able to set virtual devices device types to temp etc... or use the virtual device type plugin!
Socha thanks, good to know and the right decision! That said we have seen a long list of betas, any indication of how many more we need before you will launch the next stable version - or a time estimate?
Managed to install a 3rd party plugin now... looking forward to an official resolution
Tell me! Please!
Been informed by a nice user that it may pose problems when updating Fibaro firmware. So might be worth deleting plugin between updates until Fibaro add it back (if ever)
Tell me! Please!
Read the developer docs and work out where to load the files on the HC2. And don't even look for the file that limits the LUA environment's capabilities.
Cryptic response
Cryptic response
you sound a bit as deanrperry
