Scene to control my venetian blinds
Hello, I bought Fibaro HC2 and I'm still learning.
I want to make a scene that set my lamellas to 50% so let the sun get in the house, every week day at 8:00 AM
In the Then condition I have Then Device Group = set lamelas 0 0
What is this zeros? The second one is some timer because its in seconds but I don't get it. How can I open lamelas by 50%?
Thanks for your help, still new to Fibaro.
8 answers to this question
Guest fat
Change the zero in the green box to 50 or change the scene to Lua and use set value 50
    Thanks @fat, going to try it tomorrow morning.
    And red field is for introducing delay for this instruction in seconds.
    Everything worked as expected. Thanks.
    Now I have to do some more elaborated scene including temperature outside and some more stuff.
    Hello again people, I'm having some problems with this scene. It's just like the one in the first post but with different hours on the weekends.
    If I click run it works, If I add another 'OR' condition with for example every thursday at 11:55 ( in 5 minutes ) and save it, after five minutes it run and position the devices at 50%, but it's the second day that this scene don't run and I don't understand why.
    Can anybody help me?
    Thanks.
    Delete that second 'or' block. It introduces kind of orphan 'or' instruction to the code than can not be interpreted. I assume you will see an error in that line when you try to preview it in Lua form.
    I think that was there because I was making some tests, adding more variables, that second 'or' block was not there before I think, but I already remove it and saved lets see tomorrow if it works.
    One more question, as I'm installing more hardware ( devices like switches and dimmers ) and some times I cut the main power off, and shutdown / power on the HC2, could it mess with scenes? :/
    Thanks.
    Another day, another FAIL :/ No scene have ben ruined today again. :/
    Here is the scene in block/and lua:
    Yesterday I deleted the scene and created a new one ( this one that is not working too ), just to be sure that everything was ok...
    So what am I doing wrong? 3 days and I don't get it.
    In the general panel of the scene I selected:
    Active scene and Start when Home Center 2 starts.
    And what gets me really mad, it's because I know the scene is well done, because If I change the scene time for some time within the next 5m the scene starts automatic, then I only change the time for 8:00AM again and save and tomorrow it don't work again, maybe the HC2 enter some level of standby, I'm not getting it! :/ :/ :/
