Hello, I have some bugs with FRS's, I bought 50 switches and I tried few produced 2/2015, and it's not working properly. I can control them, but I can't edit preferences, there is no options f.e to use it as momentary switch etc.
After adding I can't remove it from network.
I tried others from 2014 and each works properly, but new ones not.
Are there some known issues with it ?
Please help, best regards
Can you provide what controller you are using it with? And what version is it?
    HCL and HC2, in two separate houses.
    Switches v 2.2 and v.2.1
    And what version of HC2 and HCL software are you working with? That is important as there have been instances of users unable to delete devices. I thought this has been fixed in 4.042 for HC2. Not sure about HCL.
    Guest chaicka
    The bug is not entirely fixed in 4.042. I re-open the bug and hope it is being looked into.
    Also I noticed that after adding Fibaro 1x3kW relay, two devices are showed, f.e real one is id 60, other one is 60.2, I can't control other one but it's showed
    • 3 weeks later...
     What version is the controller and module? You should have 3 devices: one main device that react normally, second one that is copy of first one (do not be bothered by that one, it is there due to some Z-wave requirements) and 3rd one - this is kind of virtual switch that can be toggled with s2 and use in scenes etc. If this is not true for you, you may want to check if device is configured.
