gusti67 0
I integrated an IPX800 V3 to HC2 interface.Attached is the virtual device for reading and display 1 to 4 digital inputs.I have a problem with updated values when reading data from IPX after few minutes.
For example after I created the virtual device and opened if I change one input on IPX (using IPX interface opened in another browser tab) the value on virtual device change according to the new state. IF I don't use for some minutes the HC2 interface when I change again input state on IPX the state on HC2 virtual device don't follow the new state.
It's not a browser problem (tried CTRL-F5 to update the page). Strange is that the only way to make thinks working again it's to open virtual device (if closed ) and push SAVE (no modification - just push SAVE) and after few second everithing work again until a new pause ( two minute) occur.
Any ideea why the Main Loop code stop working after an inactivity period ? (in Main Loop header it's write "In main loop you can enter LUA code to be executed each second")
Thanks,
