Is it correct that some dimmer versions have a "declared power consumption" section on the template and some don't ie
My some (maybe just one which is really weird!) v1.9 ones don't but my v2.2 ones do?
I would have thought this static value would be something used inside HC2 itself and not a feature of the modules firmware revision?
Any ideas?
I have dimmers v1.6; v1.9 and v2.2  all of them have possibility to add declared power consumption. Try to do soft reconfiguration to this dimmer, maybe it helps?
    Actually just an update.  I think it is something to do with the "Show Energy consumption measurements" not being ticked.  Trouble is I click it in 4.042 and press save and then look again and it is unticked.  4.042 issue?
    I have same issue with my HC2.
    Some of my devices was containing the block "Declare power consumption ", some others not.
    I clicked on soft reconfigure device but nothing change.
    Moreover, after a soft reconfigure on devices where I was able to select the power consumption, the option disapears.
    Now, I am in the same situation of juwi. I'm not able to tick and save "Show energy consumption measurements"
    Is it a bug?
    There are at least 2 bugs related to this in the bug tracker: 2964 and 3099. The last one has been acknowledged, awaiting fix.
