Guest nohed Share Posted May 3, 2015 does anyone know if Hc2 in vertion 4 .. has support for danalock Quote Link to post Share on other sites
0 Guest vipernor Share Posted May 4, 2015 not supported, I'm afraid. There might be a small hope in there next version though. I am still waiting for the older polylock/polypad to be supported myself. Quote Link to post Share on other sites
0 jackysgh 0 Share Posted June 5, 2015 Hc2 in vertion 4.042 Has supported danalock Quote Link to post Share on other sites
0 Sagittarius 1 Share Posted June 12, 2015 Where i can't find it? Quote Link to post Share on other sites
0 viperlodz 20 Share Posted June 12, 2015 Write to me or http://www.fibaro-lodz.pl/sklep/en/modules/58-zamek-automatyczny-danalock-okragly.html Quote Link to post Share on other sites
0 Sagittarius 1 Share Posted June 13, 2015 I dont see any plugin or luna with your link? Quote Link to post Share on other sites
0 viperlodz 20 Share Posted June 13, 2015 You need only dsnalock and hc2 without any plugin or lua. Just add lock to hc2. Quote Link to post Share on other sites
0 ivhansen 4 Share Posted July 23, 2015 How did it end with your Danalock. My lock will include but not respond to anything or show status Quote Link to post Share on other sites
0 northyorks 35 Share Posted July 23, 2015 I have danalock working fine. You have to add it then wake it to make it work properly. Took few tries and I had a few inclusions where it added but would not respond. I had to reset it, remove it from HC2 and remove batters for a min or so to allow another include. (i just pulled up the battery contact for a min or so). Quote Link to post Share on other sites
0 Guest vipernor Share Posted July 28, 2015 I have danalock working fine. You have to add it then wake it to make it work properly. Took few tries and I had a few inclusions where it added but would not respond. I had to reset it, remove it from HC2 and remove batters for a min or so to allow another include. (i just pulled up the battery contact for a min or so). This is good news, thank you for the information. Maybe there is hope after all. I'll assume you only have on/off functionality here? Quote Link to post Share on other sites
0 Guest vipernor Share Posted November 5, 2015 Have anyone successfully included the Polypad together with the Polylock or Danalock? Quote Link to post Share on other sites
Guest nohed
Link to post
11 answers to this question
