Morcegolas 6
Hello, I have some scenes to control my lights:
Scene 1- If motion is detected, then turn ON light and change Variable = AUTO.
Scene 2- If Variable == AUTO, then change Variable = RUNNING and after 60s ( turn OFF light and change Variable = Manual ).
Scene 3- This is for stoping the Scene 2, If I press a switch, then turn light ON ( because it turned OFF when I press the switch ) and Stop Scene 2 and change Variable = Manual.Scene 4- If motion is detected and Variable == RUNNING, restart Scene 2 ( to restart the 60s timer if motion is detected ).
This is the code of the scenes:
Scene 1:
Scene 2:
Scene 3:Scene 4:
My question is, as I'm really new to Lua, and Fibaro HC2 I want to know if somehow I can optimise this to use less scenes, I think that Scene 2 ( 60s timer ) have to be separated, so I can restart the 60s timer but I can be wrong.
If anybody is in the mood and want to help I'll be appreciated.
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />Thanks.
Edited to say that I have to remove the Scene 3, I don't now why but that was messing up with all the rest, and with the Scene 4 to restart the timer I can remove the Scene 3.
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Edited by Morcegolas2 answers to this question
